Earlier today my monitor suddenly went black and my entire PC locked up. I had to force the PC to shut down by holding down the power button.
I then restarted the computer, got to the Win7 log-in screen, entered my password and pressed Enter. At this point the same thing happened: Black screen, everything locked up.
First, I booted in safe mode. This worked so I began to suspect these lockups were caused by the GPUs or their drivers.
I removed the GPU drivers (the latest Catalyst 15.10 beta drivers) and rebooted the PC. This worked so I decided to roll back to older, non-beta 15.7.1 drivers. This caused my PC to lock up yet again.
So apparently the issue was not the beta drivers.
I then decided to check if the issue was one the GPUs.
(Now, I have to mention that I have a very nonstandard GPU setup: I have an MSI HD6970 combined with an older Asus HD6950 overclocked to HD6970 specs in CrossfireX.)
The first thing I did was leave the 15.7.1 drivers installed and removed the older GPU and tried to run the PC only with the newer, more powerful, non-overclocked HD6970. This locked up the PC even before the login screen.
I then tried the same thing with only the older, weaker GPU installed and, surprisingly, it booted up correctly. (Although I did notice I had lost my overclock.)
I then tried the older GPU in the PCIe slot of the new GPU and that worked as well so I am pretty confident the PCIe slots are both fine. As are the PCIe cables.
I also removed both GPUs and tried making the PC work with integrated graphics only. This worked as well.
So does anyone have an idea what the problem is? Could it be that, after years of not having any problems, the HD6970 suddenly doesn't work with the Catalyst drivers anymore?
The most recent driver change I made was updating the GPU drivers to 15.10 when those were released.
Specs:
Specs:
- Motherboard: Asus P8Z68-V PRO
- CPU: Intel Core i7 2600K @ 4.2GHz
- CPU cooler: Antec KÜHLER H2O 920
- RAM: Corsair Vengeance 16GB DDR3
- GPU: Asus Radeon HD6950 at HD6970 clocks + MSI HD6970 Twin Frozr III
- PSU: Seasonic X-760
