Pc Keeps Rebooting
cthulhuiscool
I recently purchased a lot of new hardware and built a computer but it keeps rebooting whenever I try to run it. I have tried reformatting but I get the same error, it begins loading windows and crashes and reboots. I also tried running a Linux live cd I downloaded but I get the error "kernel panic-not syncing" I have ruled out the processor and motherboard being faulty so what else can cause this? Is it software or hardware?
Hardware:
e6600
MSI P6N sli platinum
2x1gb Corsair xms2
1 sata harddrive
MSI 7300le
SB Audigy 4
and a 535w psu
Well... you don't really have any software installed so.... but just to verify this, try a different Linux Live CD.. the kernel panic is likely a bad image issue... I think you'll find that you have issues with that running correctly as well.
The first thing i would do in your situation would be to tear everything down and start with a bare bones setup. Start with your mobo out of the case on a piece of cardboard, cpu/hsf, one stick of ram and your video card. Get it to post, and start adding components one at a time until you find the culprit. If all goes well, go ahead and install your os and a/v software, and then rebuild the machine being certain that everything is installed correctly... especially the mobo.. all stand-offs in the correct location and no contact between the back of the mobo and the case.. a short could definitely be causing problems.
You may also want to check the voltages on your psu..
Good Luck...
Ok so I removed a stick of memory and it appears to be working; however, when I run a memory test from http://www.memtest86.com/ it finds absolutely no errors with the removed stick of memory. Any idea why this is the case?
How long did you let memtest run?
You need to let it run for at least 24 hours.. I have seen it run fine for 18~20 hours and then suddenly start throwing errors out the ass... so let it run.
