I bought an XCUBE PC from Maingear a little over 3 years ago and started having trouble with it spontaneously rebooting right after I got it. The PC would reboot when I wasn't doing anything except browsing the Internet. I would literally leave the room and come back to find my PC had restarted. It seemed to know when I left the room! I'm a novice PC user so I immediately contacted Maingear and they were unable to figure out what the problem was (they had me run a stress test to check for overheating) but suggested I try replacing the memory. Replacing the memory seemed to fix my problem for some months, although I found some games would still reboot my computer, albeit rarely. I did some research on my own and found most all of my reboots are listed in the event viewer as kernel power 41 task 63 with a zero bug check code. Googling turned up people with similar problems but none seemed to offer a single solution. It seems reboots can be caused by most anything that goes wrong in your system.
I hadn't played very many demanding games after changing my memory but the reboots that occurred while I was not doing anything went away. Now, however, I'm getting the same reboots very frequently when playing 2 different FPS games. My PC is no longer under warranty. What should I do? I ran Memtest86 and came up with no errors. Any help appreciated since I cannot play more than 1 hour without my PC rebooting in Dead Island and Alan Wake
