PC is halting under load?..
Parabellum
Hello,
I am experiencing some strange behaviors from my computer. I have noticed that undel heavy load like FarCry, Battlefield2 and such, my PC is halting like 20-30 sec before working again.
This is happening since I have swapped my V1.02 P4C800-E to a 2.00 P4C800-E. At the same time, I did swap my old PSU (Enermax EG461P-VE) for the one in my sig, which is supposed to be even better. Also, when I installed my new motherboard, I immediately flash the BIOS to 1021. Before I made all these changes, my PC was rock stable at 3.75GHz at default voltage. You may ask, "why the hell have you swapped all this if it was stable?"... Well, I sold my old parts to a friend so that he can set up a gaming machine for rather cheap so at the same time, I did pick up "better parts". Right now, I have these problems. I cannot locate for sure where the problem comes from. I do know that if I put back my CPU at 3.75GHz, I get some error with ATi VPU recover and I am forced to put the voltage up to 1.60V.
The thing that annoys me much is that the PC is halting for unknown reasons, even if I put all back to default. I did even a clean reformat with no luck.
Any clue? I definately neep some help :(
Para
I did notice 2 things :
All voltage rails are a lot lower than with my older motherboard like
+12V is 11.7 / 11.8V
+3.3V is 3.2
+5V is 4.9
Before, they were all above their respective rating.
Also, the temperature are a lot higher. Idle, my PC was like 26ºC. Now, it is 33ºC. I don't know if it is due to motherboard revision...
The thing I can do for now is to test the PSU in another machine to see if I get higher readings. Also, I can revert back to BIOS 1019 which has proven to be stable as hell.
Para
almost sounds like the video card is overheating.
have you run prime95 and memtest?
Not yet. I do not experience artifacting so far.. My side panel is removed. I will try memtest just to make sure this is not related to memory.
Thanks for the info,
Para
I have just run a stance of memtest 3.2 and I get a lot of errors only after 10 minutes, almost 600 errors. Most of them were on test #7.
I think I will have to memtest each stick separately to see which one is dead..
Para
