- May 18, 1997
PC Hound Updates 2/25/2015
https://pchound.com/
Updates:
PC Hound Updates 1/26/2015
PC Hound Updates 1/3/2015
- Product depth has been greatly increased by over 9X
- Hundreds of search filtering options have been added across multiple part categories
- The item selection pages now allow you to sort by columns specific to each part category (i.e. $/GB for RAM and $/GB for SSD)
- New part categories have been added including optical drives, case fans, thermal compounds, sound cards, and networking cards
- PC Hound now provides wattage estimates for your build and checks power supply wattage compatibility
- A detail page per product with a direct link that provides quick reference for item specs, price comparison, and price history has been added
- Many search filters now use sliders for easier input
- Merchant dropdown list is now sorted by price
- PCIe slots on the motherboard are now being checked for compatibility with the number of video cards in your build
- Descriptive mouseover tooltips have been added to many icons
- Search filters window now stays open as you select your filters and will apply each selection immediately
- When adding more than one item in a part category, a new menu appears that allows you to replace an existing build items or add a second or third without moving in and out of the build sheet
- OutletPC has been added as a merchant option however it is NOT turned on by default
Updates:
