PC Hound System Configuration Tool
Chris_Dickson
PC Hound / Hover Hound Lead Developer
What is the PC Hound System Builder?
The PC Hound System Builder is a tool that will allow anyone to configure a Do-It-Yourself PC build in minutes...or even seconds without leaving the PC Hound site.
The PC Hound System Builder will ensure component compatibility. It will also supply you with up-to-date pricing at all major USA etailers, such as Newegg, Amazon, TigerDirect, NCIX, Best Buy, and B&H Photo, plus a few others and put you a click away from that etailer’s product page.
PC Hound - Updates 8/24/2015
  • Introducing Hound-O-Matic (Alpha), the first fully dynamic PC system builder. Set a budget and filters, then let us do the work! (This is an Alpha: Expect errors. Please provide feedback!)
  • Streamlined interface for adding parts
  • PC Hound rank and aggregate merchant ratings now appear on item detail pages
  • Clicking outside a modal window, or pressing the ESC key will close the modal window
  • Custom build names now appear in reddit and vBCode
  • B&H Photo Video added as a merchant
  • Deeper item selection for older parts (about a 2x increase)
  • Even more speed improvements for search and price history
  • Fixed a bug that could cause items to disappear or change item IDs abruptly
  • Fixed 1TB hard drives sometimes showing up as 1GB in the search list
PCHound.com
Previous Updates:
PC Hound Updates 2/25/2015
PC Hound Updates 1/26/2015
PC Hound Updates 1/3/2015
