Ok so i decided to give my pc a quick clean out, remove the RAM, Video Card, Sound Card, Unplugged Hard Drive and clean them off and put them in. Then i plugged in this 120 gig barracuta that i havent had in it for quite some time. Booted it up and it went to a part where it would load into a part where it says Load Disk let it sit for a couple seconds then it says Disk Boot Failure. booted it down, then booted it up again and went past that although this time it went to a Disk Check. let it do the disk check. started loading windows then it looped around again and did the same thing. Im guessing my Windows HD is dying, or my MOBO went to hell. Any suggestions.
