PC Health Status Failed
LucasG
I recently got a new WD Caviar SE16 and after a few days/weeks it started doing a really weird noise, thought it was actually my room fan that was making the noise so I ignored it.
A few days ago I noticed it was the new Hard Drive I ordered. Since it was my first time using SATA I wasn't sure if it was ok to use it with my IDE but I did. I noticed it was pretty hot compared to my past Hard Drive and thought it was getting overheated so I decided to break the combination of IDE/SATA and removed the IDE Hard Drive.
The noise stopped for a few days. Yesterday I started noticing it again, but now, my computer even has some short freezes from time to time and the noise is more often.
I just decided to check my PC Health Status through the motherboard and it says:
DDR25V: Fail
+3.3V: Fail
+12V: Fail
I've already ordered an RMA from WD. But still, my mobo gives those failed status', is there something wrong?
Looks like a bad power supply to me. The sound was prob the power supply's fan failing.
The hard drive is fcking up really bad, It just did the noise hard, loud and long lasting and the computer was freezing a lot while gaming. It's definitely the hard drive and probably the power supply too.
What is your PSU (brand, model watts)? I willing to bet it is more the PSU than the HDD.
RaidMax 420W, and the Hard Drive is going bad. The IDE hard drive worked just fine.
Anyone knows what this means? Can I still overclock or should I go and get a new power supply?
Yes bad power supply as I've already said. The motherboard is telling you that according to its readings the voltages are off. While this could be the motherboard reading the voltages wrong or having other issues(bad caps) the chances of it being a power supply are a lot better. Unless you have a good voltage meter and know how to test the power supply while putting a load on it you need to just replace it.
If you got a DMM (Digital MultiMeter) then you can check the voltages for yourself and see if it is the mobo that is causing it or the power supply.
