PC Freezing/Crashing Intermittently
Unsane25
This is a relatively new build. I'm trying to diagnose the issue but I am finding it more and more difficult to pin-point what the problem is.
The PC freezes/crashes during gameplay of several titles and will even lock-up after sitting idle for several minutes/hours. I have enough experience with hardware to diagnose these kinds of issues, but this one seems to be eluding me. I assumed I was either having temperature, memory or video card driver issues as these have all lead to similar problems in the past, however, all of the above has been tested and seem to be normal.
Specs.
Asus P5WD2 Premium
3.6 P4 560 W/ Gigabyte 3D Rocket HSF
2GB Giel DDR2 - 533
Gigabyte 7800GTX @ Defaults
SATA WD 200GB (main)
SATAII Hitachi Deathstar 250GB (backup)
The CPU is running up to 70C in some cases during full load, but as this is one of the higher-end Prescotts the temperature seems nominal. I have other Prescotts that run this high. I have tested the memory, several times, with several different mem-test applications, all of which show no errors. I have tried using several different drivers for the video card, and again, not one thing is fixing the problem. I think in my frustration I may be overlooking something minscule that is the cause of the problem. Anyone with a similar experience or with any advice feel free to give some suggestions.
Note: I am very hardware profficient so explanations do not have to be dumbed down.
Have you tried using a different PSU to rule out that possibility? What kind of wattage does your PSU supply? That Prescott & 7800gtx combo would be power hungry.
It's an OCZ Modstream, of which I have two, both the 450w and 550w models, currently the 450 is in this machine, but a 450w PSU, especially of this quality, should be more than enough to handle the Prescott and the 7800GTX.
I wouldn't be too confident in that PSU... it may not be your problem, but I wouldn't rule it out that quickly. How close are the rails to spec (under load)? And what are you using to monitor them? A nice multimeter, or the mobo monitoring software? Also what is the fluxation like?
Fluctuation, http://www.mirriamwebster.com.
Unsane, as knocky as it may seem try setting up a live distribution of Linux or a desktop installation and running that down with some applications. It might be your Windows having some bad memory leaks/driver corruption or something of that sort. I always blame software because it's the easiest to diagnose and fix, because if it's a new installation and you don't mind... a format is only 15 minutes and a possible timesaver.
Actually not a bad idea, something I haven't thought about yet, thanks for the advice Heko, though its been so long since I've used Linux I'm a little rough on which distros to try for an easy diagnosis. I'll check around a bit and post findings later. Thanks again.
I haven't monitored the PSU, but I doubt that is the problem. I'm confident in the quality because I've heard nothing but good things about these power supplies since they've come to market, though I'm sure getting a lemon isn't far from improbable, I would assume I would be having more headaches than I am now had it been the issue. I might try and get a hold of some monitoring software to be sure it's not the problem.
After a lot of testing and monitoring I have found this freezing issue tends to happen during network usage. Either during an online based game, like MMOs or FPSs, or during times of downloading, especially when using Fileplanets download manager or after downloading several files from one particular site. If anyone has had a similar experience please feel free to offer an explanation or solution. As a side note I am using the built-in Lan of the motherboard instead of a peripheral add-on.
Have you tried disabling the onboard NIC and put in a regular add-in card to rule out that possibility? Have you tried using different drivers for the onboard NIC?
Actually no, because up until now I never really knew that could be an issue. However, that is my next step. I'm not about to let this build get the best of me.
Two suggestions:
- Set Windows to halt and report errors, rather than simply restart.
- Run Memtest 86 to check for stable RAM settings.
To configure Windows to report errors:
- Start/Help and Support
- Type 'error' in the search box
- Follow instructions of topic: 'Specify what Windows does if system stops unexpectedly'
That'll take some of the guess-work out of diagnosis.
For Memtest86, focus on multiple passes of Test#5 and Test#8. To start multiple passes of a particular Test#:
- Start Memtest86
- Enter key sequence 'C 1 3 (Test#) Return 0' to start multiple passes of Test#
Hope this helps!
Ive sadly run memtest 6 ways from sunday, memory is fine. I wish it were that simple, same goes for windows, configured it as you said a long time ago. No luck.
You said it seems to occur during network activity. Disable the onboard NIC in the BIOS, if you have the option, as sometimes windows is too stupid to know what it's doing. You could also try reinstalling your network protocols, as they may have become corrupt for whatever reason. I've had to reinstall the TCP/IP suite that comes stock with Windows before due to corrupt installs.
As a side note, you might want to run a test for trojans or a virus. As unlikely as it might be, you may want to do a scan for rootkits. With the whole Sony scandal, there's no telling what is going around now. I believe sysinternals has a good rootkit scanner. Poorly hooked rootkits can cause no end of problems, including lock ups and crashes.
