NeilManlius
- Nov 14, 2012
Hi there!
I've got a very big problem with my PC and I just don't know what to do about it. Sometimes, my PC comes to freeze and restarts with a blue screen or no blue screen at all appears and I have to push the reset button. Sometimes the screen becomes black or the screen becomes black, then the image reappears and the notice "Display driver stopped responding but has recovered" shows up, but mostly the PC freezes right after that.
These crashes are not reproducible although they seem to occur more likely when the system load is quite high or if the video card temperature rises above 160 °F.
My system specification:
CPU: AMD Athlon II x4 630 4x2.8 GHz
Mainboard: Gigabyte GA-M720-US3
RAM: 2x2048 MB Kingston ValueRAM DDR2-800
Video card: Point-of-View Nvidia GeForce 9500 GT (Driver version: 306.23)
Chipset: Nvidia nForce 720D (Driver version: 15.56)
HDD: Seagate ST3500418AS
Power supply unit: Tagan 500 W
OS: Windows XP Home SP3 32-bit & Windows 7 Professional SP1 32-bit
If a blue screen shows up, it mostly bears STOP code 0x00000116 and a message related to "nvlddmkm.sys" which, as I found out, is part of the Nvidia display driver.
Crashes occur when Win7 is running as well as when WinXP is running.
I assembled the system about 3 years ago and the crashes started to come up a few months later. I've also done numerous driver updates and reinstallations of Win7 but then problem continued to exist. Also a change of the power unit (from NoName 420 W to Tagan 500 W) did not improve the situation. First I though about a chipset driver error and updated the chipset driver. After that, the problem didn't show up again for at least a few months until the next crash came up.
I thought about a video card error, so I made a test and replaced the video card by my old ATI Radeon X550. After that, the PC only crashed once in two weeks but still in the same way as described.
Then I checked my RAM using Memtest86 v4.0 and Windows Memory Diagnostic. Both Memtest and WMD found some errors but when I ran Memtest again, no errors were found at all.
By the advice of some other hardware experts, I checked the voltage values of my PC and found out that the RAM voltage, which should be 1.8 V, was always at about 1.952 V. However most RAM manufacturers only guarantee correct function of their RAM modules within 1.8 V +/- 0.1 V, so my voltage is already 0.5 V above the maximum tolerance. Nevertheless, other people told me that occurred frequently with Gigabyte mainboards.
I also tried Linux Mint 13 x64 from a Live CD but everything worked fine.
So I find this situation quite paradox:
- The blue screen messages indicate a video card error but the problem persists(?) with another video card.
- The freezes imply a memory error but why does the system work fine under Linux Mint?
- That the system works fine when running a Live CD OS might imply a hard disc error but why does the blue screen come up with a video card driver file then?
Does anybody of you know what causes this problem or has anybody ever experienced something similar?
THX in advance.
See you,
NeilManlius
THX in advance.
See you,
NeilManlius
