PC for my g/f
devman
Building a PC for my girlfriend, doesn't need to be anything spectacular. She likes playing CS:S and DotA.
Anyway the build I was thinking is as follows:
CPU:
Intel Core 2 Duo E4400 Allendale (2.0GHz)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115014
Mobo:
MSI 945GM3-F LGA 775 Intel 945G Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130060
Video:
eVGA 7800GT
(Recycled from an old build)
RAM:
CORSAIR ValueSelect 2GB (2 x 1GB) DDR2 667
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145098
Hard Drive:
WD Caviar SE16 WD2500KS 250GB SATA w/16MB
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101220-12
Case:
ENERMAX VOSTOK ECA2020 MicroATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811124127&Tpk=ECA2020
PSU:
Antec SP2.0 450W PSU (Recycled from the same build as the GPU)
3.3V-30A : 5V-32A : 12V1-15A : 12V2-17A
OS will be Vista Home Premium.
Comments/Suggestions would be much appreciated.
Looks fine. The only thing that would concern me is that board shipping with a BIOS that wouldn't recognize the E4400.
Also, the PSU may be a bit weak, but as long as you're not OC'ing, it should be ok.
No, the E4300 wouldn't be safer. If the BIOS won't recognize it, MSI should either send you a new board, or a bios chip (if its just a simple plug).
