PC fails to boot with HDD connected
Good morning all! Sorry for the length of this post but I'd rather give all the information in one go to cut to the chase quicker and save you asking me questions that you would have otherwise skipped.
Last night I decided I wanted a copy of trusty old XP installing so I could dual boot either Windows 7 or XP. I already had W7 installed so it was a simple process of shrinking the volume, booting from the XP CD, formatting the now unallocated space and installing XP to that new logical drive.
Windows XP installed successfully and the system proceeded to reboot. So I set BIOS to boot from the HDD, expecting to be presented with the option of choosing which drive/operating system to boot, only it hung up and wouldn't go any further. The POST completed successfully but when I was presented with the 'Packard Bell' logo for the second time, usually right before it says 'Starting Windows', nothing else happened. The drive wasn't churning, the PC was doing nothing. I tried a normal switch on like this several times. Annoyingly, I can't turn off the 'Packard Bell' logo in the BIOS so I can't see what the system is hanging up on.
I then figured, the install of Windows XP must have screwed things up, so I reinserted the CD and set to boot from that again with a view to either trying the process again or formatting the entire drive and starting a fresh. However, the problem reoccurred despite the HDD not being in the equation - the only boot device was the DVD drive and all the rest were disabled.
I then decided to try booting from the DVD drive with the HDD disconnected, and this time it loaded up as expected. Powering off and reconnecting the HDD caused the problem again.
Now I'm not sure if SATA drives are 'hot' swappable but I thought, "it's probably screwed anyway" so I powered down, disconnected the drive and booted from the W7 DVD. Then when presented with the option of which drive to install W7 on, I reconnected the HDD to the SATA port and hit 'refresh' - nothing (but I'm not sure if there would have been anyway!).
My next thought was, "I have a 32Gb USB drive, maybe I can install and run Windows from that, and see if I can format the HDD from within Windows" only, it was not visible (should it be?).
So basically, I'm stuck for the time being, unless anyone has any thoughts? I do have a laptop which I could use to create a bootable USB stick from, I just didn't get that far last night before I had to quit and make dinner - but will it even work if I couldn't boot from a CD with the HDD connected?
Your help is much appreciated!
packardbell computer ? really, this sounds like a OLD OLD OLD computer.
specs on machine ?
It's really old, but it was free and I thought it would be a good start to get back into the world of PCs - been out of it for a while now.
Unfortunately I'm at work so I don't have the full specs right now but I'll attempt to remember what's what off the top of my head:
Motherboard: MSI MS-7069 Ver 1
Processor: P4 2.93Ghz
RAM: 3Gb DDR PC3200 (3 X 1Gb sticks)
PSU: Stock 315W
HDD: Stock (I believe Seagate) 80Gb SATA
Graphics card: PNY GeForce 8400GS 512Mb (PCI)
Optical Drive: Stock Samsung DVD-R/RW
OS: Windows 7
If there's anything else that you need to know, let me know and I'll find it out. If it's any help, here's a link to a site selling the motherboard with the full specs: http://www.dhgate.com/msi-ms-7069-n...rated/p-ff8080812d270a19012d27a2e0b2486b.html
Also, for what it's worth, the model is a Packard Bell iMedia 1503.
Thanks!
Have you tried resetting the BIOS to defaults, reset the HDD as the boot device and try again? Also, many systems that have bios boot logos allw you to hit tab or f10 and see the boot screen instead of the logo (don't know about packard bell though, damn that is a name from the past)
Yeah I tried resetting the BIOS to default values, same result. Tried a fresh battery for the CMOS, same result. Tried jigging the settings in the BIOS, same result :(
I'll try hitting F10 tonight to see if I can view the boot process but I don't remember seeing the option. It has "Esc - Switch Screens, F2 - BIOS, F8 - Select Boot Device" if memory serves me right. Changing the boot device in BIOS had no effect as I mentioned above, and selecting the boot device by htting F8 didn't either.
Well, it is possible that the boot record has been trashed on the machine. If you don't mind wiping the drive, grab a ubuntu live cd, install linux to the drive and see if it boots from that. Or, if you still have the windows 7 install still on the drive boot from the win7 cd, and do a startup repair.
That would be the normal course of action and I did try that, I've nothing on the drive worth keeping so I was happy to wipe it. Win7 is still on the drive, but I can't boot from CD to do a format and fresh install or repair. If I select to boot from CD with the HDD connected, the boot sequence halts with the 'Packard Bell' logo after the POST has completed successfully. If I disconnect the HDD and opt to boot from CD, it boots from the CD fine. It's got me puzzled!
Well, if you have another hard drive to test with, plug it into the machine and see if the problems subside. Do you hear the drive spin up? Is it detected properly in the bios? Have you tried another power supply connector (off another chain of connectors if possible?)
Unfortunately I don't have another HDD to test with, or another machine to test this problem child of a HDD on. The drive does spin up briefly when powering on and it is detected in the BIOS. This would suggest it's getting power (although maybe not enough to operate normally - your thoughts?). I only have one SATA power adaptor but there are plenty of alternative power connectors to try this on.
If this was a motherboard issue (Southbridge?), would BIOS detect the drive, and would I be able to boot from the ODD with the HDD disconnected? If not then I can rule out the mb, in which case I can attempt to run it off different power connections to see if that solves the problem. And if that doesn't work, I can rule out the power connections and it would leave me with the SATA cable, the SATA power adaptor and the HDD itself.
Sounds like the drive needs a fresh format, sounds like you tried to many times and killed the MBR.
Hope the data wasn't valuable. If it was u need to take it to a known working computer and attach it to that and grab the data.
Dash.
Nah, it was virtually empty. No great shakes, just time consuming doing a fresh install. I can't format it from the PC it's in because it won't boot with the HDD connected, so I'm borrowing a friend's tonight and doing it on his and seeing where that gets me.
I'll post results tomorrow for continuity in case anyone stumbles upon this thread in the future.
In my experience, installing XP after Win 7 mucks up the MBR, but it just breaks the dual boot (so booting goes straight to XP) and using a Win 7 to repair the MBR will get the dual boot option going.
Your problem sounds more like the drive has gone bad. If that drive is old, especially if it is the original drive in the machine, then installing a second OS on it may have used up what little life it had left.
YOu don't need it to boot to install windows.
Boot off the windows cd, id download the manufactures hdd tools and format the MBR since that sounds like the issue. THEN you can install windows and go from there.
Sorry if I didn't make it clear in the first post, but the system would not boot to any CD (XP or W7) or bootable USB drive with the HDD connected so I couldn't repair the MBR.
The point is moot anyway, I flattened it last night and removed all partitions using the second PC. It then allowed me to boot to CD and I reinstalled XP without a hitch.
A waste of time really as I'll be putting W7 back on it in a few days when my 8400GS arrives, but at least I've proved the drive and all the other components.
Thanks for all your help guys (girls?), looking forward to contributing to the forum now I'm back in the game!
