My 3+ year old PC is dying, and I need to replace it....This will go in my Bedroom (to watch TV, etc at night) so the main requirement is that it needs to be QUIET and COOL. I plan on doing some OCing, but nothing huge. Also, i want to re-use some the parts from my old PC, like the video card, the Power supply, the DVD-drives, Case, etc.
ok, here is what I got so far:
two (2) Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $77.99 each
# Model #: WD2500KS
# Item #: N82E16822144701
Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775 Processor Model BX80557E6300 - Retail $185.00
Model #: BX80557E6300
Item #: N82E16819115005
ASUS P5NSLI Socket T (LGA 775) NVIDIA nForce 570 SLI Intel Edition ATX Intel Motherboard - Retail $119.99
Model #: P5NSLI
Item #: N82E16813131032
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 675 (PC2 5400) Unbuffered System Memory Model TWIN2X2048-5400c4 - Retail $199.99 (after rebate)
Model #: TWIN2X2048-5400c4
Item #: N82E16820145015
1) should I upgrade to this mobo?
http://www.newegg.com/Product/Product.asp?Item=N82E16813131030
SUS P5B Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail
Item #: N82E16813131030
2) I also have this PSU...is it good enough, or do I need to upgrade?
http://www.ocztechnology.com/products/power_management/ocz_powerstream_power_supply
the 420W version....
3) what heatsink/fan cooling should I do? or is watercooling the only alternative?
I looked at the swiftech Apex Ultra H20-220, but it doesn't support the LG-775 socket for Conroe....any ideas?
# Model #: WD2500KS
Model #: P5NSLI
