Pc doesnt post after change cooler
beheo2019
Bad Trader
I just installed the swiftech aio. Before I put the cpu block, I also reseat the cpu. I turned on the machine and it said I need to go to bios coz new CPU. I went there and hit f10 to save then pc doesnt post. No light on keyboard and screen os black , just rgb on the pc is on.
Sounds like maybe you damaged socket when you reseated CPU. That 's first place I would look. If all looks good maybe put old cooler back on and see if it works. That's what I would do.
If can get back into the BIOS I'd reset it.
If not, pull the CPU out and check for bent pins or debris in the socket and on the back of the CPU.
Its the ram, somehow when I reseat the cpu, the ram cant run at 4000mhz anymore. Back down to xmp 3200.
