PC Building HELP HELP!!
Apologenetic
Ok here's the setup:
MSI Neo2 Plat
A64 3200+ .09n
Antec TP 480
Plextor 8x DVD burner
120GB Seagate IDE
80GB Seagate SATA
Here's the Problem:
I'm building a new system and want to keep an old 120Gig IDE drive that has my life on it. And I'm also installing a brand new 80Gig SATA drive. Now I know on a new system a clean format for a windows build is required so I set my IDE HDD and DVD burner to "Cable Select" where it recognized both IDE drives and my SATA drive but it wanted to boot from my old Windows XP boot on my IDE drive which is impossible. So I restarted and booted from a Win XP disk to install on my SATA. Now the install went through but now with "Cabel Select" on both drives it only boots from My IDE and won't see my SATA boot but if I change the IDE HDD to Slave I can boot into the SATA Windows but with the IDE HDD on "Slave" it won't see my DVD no matter what jumper it's on or if it does it gets a "Check Media" error. So I guess my question is; How can I get my comp to see both IDE drives which need to both be in "Cabel Select" to both work (I think) and still have it see my SATA boot over my IDE, Can I disable my IDE boot from Win Repair?? if so, how? I really really don't want to format my IDE HDD so I prefer solutions that don't include this because if I have to do that I already know how I'm just looking for alternatives.
Thank you in advance for any help
sounds like it might be your boot settings in the bios.
boot up into bios and check 1) your bootup order 2) your recognized hdds.
you may have to change the settings so it will check your SATA drive first for a windows install.
this same thing happened with my Asus board, its not to hard to fix
Do not hook up your old drive while installing to make sure that the data is not lost. And as is the post before be sure to set you boot order correctly in to BIOS.
Lothar
MSI Neo2 Plat
A64 3200+ .09n
Antec TP 480
120GB Seagate IDE
80GB Seagate SATA
Here's the Problem:
I have much better idea for you...Boot off ur Win XP cd and go into ur IDE HDD and delete tha partition with all rus tuff on it....when you go to delete the partition it should ask if u want to format it and save the file system which will just delete ur windows and save your files..
are you sure about deleting a primary partition with all the personal files on it wont in effect be the same as formatting? I think hes gonna lose all his files , not just his windows files, if he does that.
