anutoshi said:Found these kits, look ok, not great, anybody?
http://catalog.belkin.com/IWCatSectionView.process?IWAction=Load&Merchant_Id=&Section_Id=109
The best toolbox is your own build.
Yeah. Jensen Tools (which is the same company as Contact East) rocks. I built a semi-custom kit into a much larger briefcase than it was designed for so I could add my own tools.BlindedByScience said:...not the cheapest, maybe not the best, but my set of Jensen tools lived through building several recording studios, a tour or two, and now live comfortably on my bench in B.B.S. labs. Got 20+ years on my set, for sure.
mikeblas said:Do case modders really thread anything? Most of the stuff I've seen has been pop-riveted.
mikeblas said:Cold heat soldering tools are garbage. They're a gimmick; if you use 'em just right, they work. I'd rather not worry about my tools so I can focus on the job -- and that means I'll whip out my trusty Weller.
Screws for cases and PCI tabs are #6-32 by a quarter of an inch.
The little standoffs are odd; the motherboard is held to the standoff with a M3 x 6mm screw, but the baseplate has a #6-32 tap. So those little brass standoffs have both metric and imperial threading. Neat, huh?
Some disk drives use a #6-32 screw, others use a metric M3 screw. The length might be 6mm, but could be shorter to not penetrate into the drive or its mounting hardware.
Anyway, you just need a set that has those sizes. Or, I guess you could go buy the individual taps and dies.
GeForceX said:The best toolbox is your own build.
