Posting this for a friend. He's mainly concerned about which motherboard to get now-a-days. Anyways, thanks in advance.
1: What will you be doing with this PC: Gaming
2: What's your budget? $400-ish total
3: Which country do you live in: FL, USA
4: What exact parts do you need for that budget: CPU - Intel Core i5-2500K ; RAM - 8gig minimum, all
around good quality ram (stable, decent rate/timings) ; Motherboard - this is the part that I need
advice on.
5: If reusing any parts, what parts will you be reusing: Case - Antec 900, Video - GTX 560 ti, Hard
drives - WDC WD10EADS-00L5B1 and Samsung HD204UI
6: Will you be overclocking: yes, have a Corsair H80
7: What is the max resolution of your monitor: 19inch 1440x900
8: When do you plan on building/buying the PC: around March 12
9: What features do you need in a motherboard: USB 3.0, not sure of any other features
10: Do you already have a legit and reusable/transferable OS key/license: Yes
advice on.
