PC-A10 Window kit or side panel. I need directions
jakegub
I am about to be the proud new owner of a Lian-Li PC-A10. Has anyone seen windowed panels available or am I going to have to cut up my nice new case and add a window? I would obviously prefer to buy the panel, unless it is too ridiculously priced. If anyone has seen any or knows if something like this would work let me know.
Thanks
I just did a quick look over Performance-PCs, and they don't seem to carry one. I would imagine that they'll start making one in the near future, cause nearly all Lian Li cases have window side panels available.
is performance-pcs the place to be looking? Does anyone know if my window panel would be compatible with another one of lian-li's cases. It seems like they would only stand to profit from having interchangeability in their parts. I can deal with no window for a while, but I have this beautiful blue G.Skill ram, and I organize my wires well and I would like to be able to see all of it since it is where I spent all of my money.
You could always try and make your own window!
Also, if you really cannot wait, performance-pc's DO do custom modding.. for a price.
If you like any particular style of window Performance-PC's use, you should be able to contact them about sending your panel in for them to work on. They do the bolt-on style windows extremely well.
The PC-A10 panels are not compatible with any of the PC-60 or PC-7 series cases and the A10 panel It's wider and taller. It's been a while since I had a PC-70, but I don't think the A10 panel is the same size.
I'm going to put the Lian Li aquarium side panel on my A10B. I drilled out the rivets on the kit and have the plastic piece and a seperate frame ready to be cut into my panel and bolted or riveted on.
I know this is acient. but has anybody ever found one of these? Performance-Pc's has black, i need silver?
EDIT: Nvm. I found out the PPCs sells laser cut A10 side panels..
