PC-7B PLUS II CLEAR SIDE
wtfizzle
Hey im currently ordering a PC-7B PLUS II lian li case for my new computer. Im looking
to change the side panel into a clear side panel, kinda making it look like the lian li PC-60B PLUS II case. I found the part needed on the lian li website. http://www.lian-li.com/v2/en/produc...ex=165&cl_index=2&sc_index=29&ss_index=72&g=f
What i need help from is finding a reliable website to buy it from. Also im going to add a 120mm fan on the side vent (preferably with blue LED lights.) and i might also replace the stock 120mm fans on the front and back of the case with new ones for better airflow (with or without led lights). If somebody could recommend some parts for me i would greatly appreciate it.
Im probably going to go with the w-65PB2 side panel from performance pcs. Does anybody know whats the deal with the additional lian li air duct and fan. Is it a needed part or can i just buy any 120mm fan for the side panel vent.
you can use any fan you want for the vent, you just gotta use your imagination to find something to hold it there, thats what the lian li fan bracket is for otherwise.
