PC-767 Door Mod question
Wish
Heya,
Is the door removable? I'm thinking of getting the case and cutting a popsicle-size vertical hole in the bottom of the left-hand side of the door, in the narrow vertical strip that is perpendicular to the front of the door.
The reason would be to allow front air intake from that side of the case as well to the lower front fan.
Any suggestions as to how to accomplish this?
Anyone have this case and can offer a suggestion?
Should I just get a CM Stacker 830 and call it a day?
* wish *
