PC-6070 Top panel
KrylonArt
Recently, one of my co-workers told me that he had a bunch of computer parts that he wanted to get rid of since he was being reassigned overseas. So I took a look at some of the stuff he had and found a never used Lian-li PC-6070 that has been modified with a Koolance unit on the top panel. I can either use it as is, water cooling with the Koolance unit or I can try to replace the top panel. Does anyone know if Top Panel for PC-7/PC-6X Cases will work with the PC-6070? Also, is there a motherboard tray that fits this chassis that has 120mm fan, not really liking the fact that it is 80mm only on the fans.
