PATA vs SATA - worth migrating OS?
ococ
I have my machine now running on a 250gb PATA drive. I also have a 300gb SATA and a 1TB SATA drive. Would it be worth the time to move my OS from the PATA over to the SATA 300 drive? I'm going to keep the 1TB separate for storage.
Thanks!
Run HDTune and see which is fastest.
If theres not much difference you might as well stay as you are.
Doesn't look like it's worth it to move from the 250 to the 300. What about the 1tb? I'd like to keep it just for storage though.
The 250GB IDE drives transfer rate isnt very smooth but if you arent noticing any issues then I wouldnt worry, you might as well leave it on there unless you want to try the 1TB drive.
You can create say a 40GB partition for Windows on the 1TB drive and use the rest for data.
I'd do it :)
I thought the lack of smoothness is because it's the drive hosting the OS. Is that not the case?
Its possible that something is running regularly and accessing the hard drive.
It might be the OS or other software or the drive might have a fault.
