i have done a little searching on the forum but have not found anything about connecting PATA drives to SATA on-board controllers and there reliability.
i am currently upgrading to a new desktop computer, having worked closely with both PC and MAC, and have decided that a PC is the way to go for most bang for the buck since i need a workstation for Photoshop, Aftereffects, zbrush and PTassembler.
my setup is as follows
AMD Athlon 64 3200+
G.E.I.L. 1 GB DDR-500 Kit
Asus A8N-VM CSM
Zalman CNPS7700-CU
aspire X-Qpack
3 x PATA to SATA converters
LG DVD re-writer
2 x 120GB IDE hard drives
as you can tell, i have tried to keep the costs as low as possible so i have cut corners for now, but have chosen a computer with some upgrade potential. in order to do this i am migrating my previous hard drives (RAIDed 120 WD JBs from an old G4 Powermac) and DVD drive to this new computer but would like to use SATA because the motherboard supports it and the case is small.
i found these converters on ebay
and bought them because they are ultimately cheaper then buying them locally in my home city of berlin, germany, and buying a new hard drive would put my budget over the top.
sorry for the long post but what i finally wanted to ask was, has anyone had any expierence with these converters of converters like it? i have see posts for SATA to PATA converters but not the other way around. also, any imput on anything that involves this setup and the devices in it would be very apriciated. i am still waiting for some of the components to be delivered, and i haven't put together a computer like this since my old celeron 300A back in college!
thanks for any imput you can provide!
AMD Athlon 64 3200+
Asus A8N-VM CSM
Zalman CNPS7700-CU
aspire X-Qpack
LG DVD re-writer
