Passy to download?
my84mcss
I was wondering if there was any way to make a passy that is randomly generated every day, to download a certian file off my server. It is running Server 2003.
TIA
How are you connecting to this server? HTTP? FTP? NET USE?
What is a "passy"? A password? If so, yes: passwords can be randomly created and then set to a file. How will you find out the password every day so you can use it for the download?
it would be http. yes, passy is password. and i would have to have a way to find out the password each day.
Then, sure: You can do what you want writing a VB script, I think.
Ok, how would I go about that? I have no knowledge in programing whatsoever. I dont know how to write scripts... :(
lol...
so you want to do something somehow using a skill you don't have. :-p wonderful
I don't have a good answer for you, but it just seemed like such a general question that I had to make a smartass comment.
It might be over the top for your needs but you might want to have a look at RSA Secure ID.
You get a hardware token, which can be applyed to almost anything (even windows logon now) It changes every minute and you simply enter the number generated pretty secure seeing as you need to have the key
