firestorm99
- Nov 17, 2011
Hello,
i have a problem with passing a NIC to a FreeBSD virtual machine.
First of all my Specs:
CPU: Intel i5-2400s
MB: Intel DQ670SW
RAM: 16GB TeamElite
RAID Card: Dell Perc 6/i IT Mode
ESXI Version: 5.0
NICs:
Onboard: Intel Corporation 82579LM Gigabit Network Connection
PCI: Intel 1000 Pro/GT 82541PI Gigabit Network Connection
The nic driver for the onboard nic is chilly's driver provided in this forum.
Setup:
Pfsense vm is nat between virtual machines on esxi host and regular network. the vmnic1 is connected to the regular network.
There is a freeNAS virtual machine which owns the raid card via pass through, which is working fine. For better performance i wanted to pass a additional nic to the virtual machine(The PCI Nic). The nic was recognized flawlessly by freenas.
But then the problems started. I had timeouts spontaneous timeouts on both interfaces to the regular network.
These timeouts do not occur simultaneously, which makes it hard for me to trace it.
Setup:
network1 ---> vmnic 1--> onboard nic --> physical network A
pfsense
network2
pfsense
freenas --> passthrough intel nic --> physical network A
other vms
The problem disappears if i use a virtual interface pointing to network1, but the permance is quite poor then (~30MB/s instead of 80+MB/s). I changed cables and network equipment, but i didn't help either.
I don't think the problem is because of the custom driver for the onboard nic, it works fine as the primary interface.
My vmkernel.log: vmkernel.log
My question is now: Has anyone of you experienced a similiar behaviour somewhere?
It would help a lot if I could solve this problem.
Thanks in advance,
fire
CPU: Intel i5-2400s
MB: Intel DQ670SW
RAM: 16GB TeamElite
ESXI Version: 5.0
NICs:
Setup:
Setup:
pfsense
network2
pfsense
other vms
Thanks in advance,
fire
