RaphaelVinceti
- Apr 7, 2005
Do the innovatek's passive radiators work as well as a dual HC with silent 120mm fans, or should i spend the money on the dual HC with fans?
Also, I was looking into liquids to use, can you use straight coolant, like you would use in your car?
