passive cooling WC setup? anyone here has done it
paulmofyourhand
im going to get rid of my koolance system (cools nicely, but im bored with it already), and plan on parting together one by myself.
im trying to achieve a passively cooled radiator. im using whats in the sig, its going to have the CPU , northbridge, and geforceFX cooler.
eheim 1250 pump, Hayden transmission cooler (11"x11") with 3/8" slide on ...
im going to mount the transmissoin cooler where the window usually is. (so yea removing the door is going to be a bitch every now and then)
1) do they make a hard drive water block? what size are the fittings?
2) will a resovoir about the size of 3 CDrom drives help the temps?
3) with my 3.0@ 3.6, i wanna stay at least under 50c @ load. possible?
4) if worst come to worst, ima install a handfull of 120mm uber quiet fans (papast, panaflo, adda, or whatever) on a rheobus...
any advice or comments?
thanks in advance
-paulm
I'll try and get through as many of your questions as I can...
1) Yes, theres loads of em about. Koolance have a few out, as well as Innovatek
2) Well, the larger the res, the longer (theoretically) water should sit in the res before being sucked back into the rest of the system, thus allowing it to cool down at least a little more.... although you do have to remember warm water is still being introduced by the inlet to the res, so I doubt in all you would end up with a noticeable difference.
3) I've unplugged all the fans on my Thermochill 120.3 and loaded my system with a couple UT2003 benchmarks to stress the CPU & GFX (seeing as I have both on my W/C system (XP2700+ @ 2.3GHz & 9700 Pro)). Temps stabilized at 63c and stayed there. System was just as stable as it was at 35c, just a lot quieter :)
4) Sure, go for it. My 120s will quite happily keep my system at 40c if I knock them down to 7v without too much fuss, but I don't really have a problem with the volume so I just leave them at 12v 24/7...
(CPU) 1-AMD Athlon™ XP 2700+, 2345MHz, 256KB (100% Load) @ 38°C (Fan @ 3792 RPM), Core @ 1.824V / Case @ 25°C
For the cost of the Innovatek, you can build your own. Hell, it'd be 1/5th the price.
All you need is some copper tubing, some solder, a flat piece of metal, and some time.
Best of all, you can rig it so that you can sandwich the HardDrives on each side of the block so that you can cool 2 at the expense of 1.
MrBadidea: what size is ur radiator, and where is it located?
Spidey329: yea i saw the koolance HDD cooler install sheet, and it uses a goo thing to keep it from shorting the hard drive, where can i find an equivalent to that goo? ima be using two western digital drives (wd2000jb and wd360)
enraged78: i saw ur setup , my friends love it, but it would be inconvient for me to lug around that for LANs.
-paulm
Spidey329: i think ima attempt it, have u tried it before? and the questoin about the goop thing two post above this one...
-paulm
