OK, so my htpc just is not as quiet as i would like. so i'm taking it passive. aside from possibly the power supply, as the seasonics and enermax both of which i've used before where dead silent to me.
so i'd like to put a passive HS on my 3200 winnie. thinking either the si-120, or the ninja. yet little reserved as i've read reviews that where it is not reccomended to run anything 3200 or above on either of these HS's.
as for the GPU i'm not sure either, might acutally keep the AC cooler i have on there, its dead silent now @ 12 volts, and i could always undervolt it.
so i'm curious if you feel that the 3200 will perform no problem with either the ninja or the si, the ninja is cheaper, yet more people lean me towards the thermalright.
case restrictions should not be an issue as its the ahanix dvine 4 htpc case, quite high and large.
