Parts List, I need Feedback
Xenocide
Case-
Lian-Li Silver USB 10-Bay Aluminum Case
CD/Dvd Rom-
SONY 52X CD-ROM
CD/DVD Burner-
Lite-On Beige DVD-RW/+RW Drive
Fans/Heatsinks-
Thermalright SLK-947U Copper Heatsink for both Intel and Amd
FLoppy Drive-
Samsung 1.44MB 3.5inch Floppy Disk Drive
Hard Drive-
Western Digital Special Edition 80GB 7200RPM IDE Hard Drive
Keyboard-
Logitech Deluxe Plus Keyboard PS2 104keys
Memory-
Corsair Value Select (Dual Pack) 184 Pin 1G(512MBx2) DDR PC-3200
Monitor-
KDS XF-9I 19" DynaFlat CRT Monitor
Motherboard-
ASUS nForce2 400 Chipset Motherboard for AMD Socket A CPU
Mouse-
Logitech Cordless Click! Plus Optical Mouse USB/PS2
Power Supply-
COOLMAX 400W CT-400N POWER SUPPLY RETAIL W/ 2 Fans, 3 Speed Fan Control Switch ( Auto, Low, Medium).
Processor-
AMD Athlon XP 2600+ "Barton", 333MHz FSB, 512K Cache Processor - OEM
Video Card-
SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Total Cost: 1100.47
this price is about as high as i can go maybe 50 dollars more. im using this computer for gaming, browsing the internet, downloading and watching movies, and music, and for schoolwork.
ask about anything else you need to help you help me!
here is all the stats of the parts!]
Cases (Computer Cases, ATX Form)
Lian-Li Silver USB 10-Bay Aluminum Case, Model "PC-7"
Specifications:
Case Type: Mid-Tower
Color: Silver
Material: Aluminum
Drive Bays: 5.25'' x4,3.5''(External) x3,3.5''(Internal) x3
Expansion Slot: 7
Front Ports: USB2.0 x2
Power Supply: N/A
Cooling System: 3x 80mm Case fan
Motherboard Compatibility: Standard ATX
Dimensions: 8"Wx17"Hx18"D
Special Features: Tool-less detachable front panel more info>
N82E16811112021 $75.00
$75.00
CD/DVD Burners (RW Drives)
Lite-On Beige DVD-RW/+RW Drive, Model LDW-811S/851S, OEM Bulk Pack
Specifications:
Write Speed: 8X DVD+R, 4X DVD+RW, 4X DVD-R, 2X DVD-RW, 40X CD-R, 24X CD-RW
Read Speed: 40X CD-ROM, 12X DVD-ROM
Interface: EIDE/ATAPI
Buffer: 2 MB
OS Support: Windows 98/Me/2000/XP
Features: SMART-BURN avoiding Buffer Under Run error, VAS to reduce vibration & noise during recording & reading
Remark: OEM pack (see pictures for details) more info>
N82E16827106923 $88.50
$88.50
CD/DVD ROM Drives
SONY 52X CD-ROM, Model CDU5221, OEM
Specifications:
Read Speed: 52X CD-ROM
Interface: E-IDE/ATAPI
Buffer: 128KB
Access Time: 80ms
Data Transfer Rate: 7800 KB/sec, Ultra DMA up to 33.3MB/s
Features: Not specified
Remark: OEM Drive only(see pictures for details) more info>
N82E16827101120 $15.00
$15.00
Fans, Heatsinks (Case, CPU, Chipset)
Thermalright SLK-947U Copper Heatsink for both Intel and Amd -RETAIL
Specification:
Compatibility: AMD: Athlon XP Palamino, Thoroughbred, and Barton 2800+ and up Intel: Pentium-4 socket-478 3.06 GHz and above
Material: Copper
Dimension: L67 x W81 x H45 mm
Weight: 570g (Heat sinkonly
more info>
N82E16835109112 $42.99
$42.99
Floppy Drives
Samsung 1.44MB 3.5inch Floppy Disk Drive, Model SFD321B/LEB, OEM Drive Only
Specifications:
Capacity: 1.44MB
Average Access Time: not specified
Interface: 34 Pin Standard Floppy Connector
Form: 3.5 inch
Media Type: All Standard 1.44MB & 720KB 3.5 Floppy Diskettes
Features: Easy to Install, Just Plug & Play, For IBM5 & 100% Compatible Computers
Remark: OEM 1 Year Warranty more info>
N82E16821103202 $5.99
$5.99
Hard Drives
Western Digital Special Edition 80GB 7200RPM IDE Hard Drive, Model WD800JB, OEM Drive Only
Specifications:
Capacity: 80GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: High-performance with 8MB Buffer
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info>
N82E16822144122 $74.00
$74.00
Keyboards
Logitech Deluxe Plus Keyboard PS2 104keys -OEM
Specifications:
Interface: PS2
Number Of Keys: 104 keys + 4 function keys
Wireless Technology: N/A
Palm Rest: Detachable
Design Style: Standard
Mouse included: N/A more info>
N82E16823126129 $9.00
$11 ea.@2+
$10 ea.@4+
$9 ea.@6+
$9.00
Memory (System Memory)
Corsair Value Select (Dual Pack) 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
Specification
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime more info>
N82E16820145440 $177.00
$177.00
Monitors - CRT
KDS XF-9I 19" DynaFlat CRT Monitor -RETAIL
Specifications:
CRT Type: 19" (18.0" VIS), DynaFlat CRT
Dot Pitch: 0.25mm
Max / Optimal resolution: 1600 x 1200 @ 65Hz / 1280 x 1024
Frequency / Bandwidth: fh: 30~86kHz; fv: 50~160Hz / 150MHz
Features: Multi-layer coating, antistatic, non-glare, Extreme Flat Screen Technology
Dimensions & Weight: 17.6" x 17.8" x 17.9" (WxHxD), 43.2 lbs
Manufacturer's Warranty / Phone No.: 3 year limited parts & labor / 800-283-1311 more info>
Standard Warranty only N82E16824155032 $161.00
$161.00
Motherboards - AMD
ASUS nForce2 400 Chipset Motherboard for AMD Socket A CPU, Model "A7N8X-X" -RETAIL
Specifications:
Supported CPU: Socket A AMD Athlon/Athlon XP/Duron Processors
Chipset: NVIDIA nForce2 400 + MCP
FSB: 400/333/266/200MHz
RAM: 3x DIMM for DDR400/333/266/200(Non-ECC,unbuffered) Max 3GB
IDE: 2x UltraDMA 133 up to 4 Devices
Slots: 1x AGP 8X, 5x PCI
Ports: 2xPS2, 1xCOM, 1xLPT,6xUSB2.0(Rear 4), 1xLAN, Audio Ports
Onboard Audio: Realtek ALC650 6CH w/ built in HP amplifier
Onboard LAN: Integrated NVIDIA MAC + Realtek 8201BL PHY 10/100Mbps
Form Factor: ATX more info>
N82E16813131468 $72.00
$72.00
Mouse
Logitech Cordless Click! Plus Optical Mouse USB/PS2 -RETAIL
Specifications:
Interface: USB/PS2
Number Of Buttons: 6x buttons + 1x Wheel
Optical/Ball: Optical
Wireless Technology: RF
Features: Zip back and forth between open documents with the handy, quick Switch Button, Use the convenient thumb buttons to navigate forward and back in your web browser more info>
N82E16826104141 $39.00
$39.00
Power Supplies
Specifications:
Type: ATX
Maximum Power: 400W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: Not specified
Efficiency: Not specified
Over Voltage Protection: Not specified
Overload Protection: Not specified
Input Voltage: 100~120Vac/200~240Vac
Input Frequency Range: 60/50Hz
Input Current: 10A/6A
Output: +3.3V@28A, +5V@42A, -5V@0.5A, +12V@18A, -12V@0.8A, +5VSB@3A
MTBF: Not specified
Approvals: Not specified more info>
N82E16817159008 $45.99
$45.99
Processors
Specification
Model: AMD Athlon XP 2600+
Core: Barton
Operating Frequency: 1.9GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM(Processor Only) more info>
N82E16819103417 $88.00
$88.00
Video Cards
Specifications:
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info>
N82E168141
Everything seems to be quality part, IMO I would only change the monitor to a Viewsonic or a NEC or something like that.
I have to ask, since people do this way too often, have you already ordered any of this? I don't care for when people ask for opinions and advice when they've already ordered stuff. Wasted effort to think. :)
Great lookin' system there. That's really all you need to make a good system, and that thing would run new games soo well. Can i ask, going dual channel? Sorry if i missed it. Also, what about case fans to get good airflow in the case (again, sorry if i missed them...)
Good luck with that,
4keatimj
I agree, get the Antec for the "cleaner" power. You don't need a lot of power for that system, your components won't likely consume even 200 watts, but you don't want unreliable power being fed to them either.
3 things:
1. Spend the extra little bit of cash and get a pc-60 instead of a -7, the mobo tray beats all hands down
2. Get a logitech elite kb instead
3. Get a better logitech wireless mouse, like an mx- line or the cordless mouseman
or 2 & 3 get the wireless mx duo
Oh wow, I glossed over the PSU recommendation :eek:
If you're trying to stay in that price range, a Fortron would be right up your ally.
No, i Havent bought the computer yet, for one whats a PSU, and the things im most worried about are, are all these parts compatible, do they work good together, and will that ram be good enough, likewise with the processor? thanks for your input
if you'll be downloading a lot of movies, you might want to go for a 120 gigger. the price difference isnt too much, and movies are anout 600 mb to 4 gigs these days. usually about 1 gig or 1.5 gigs.
Did you forget to get a fan for the hsf?
The 947u is good, but not good enough for passive cooling ;)
What kind of movies are we talking about here? ;)
Millow as your self appointed counsel
Id advise you not to answer that, because while you might be in Canada
the server for this forum is not :p
a quick review of the rules might be in order ;)
the term "illegal" is to be interpreted as illegal in the state of Texas :p
im talking about whatever type of movies he's planning on downloading, thats all :cool:
Originally posted by Ice Czar
]the term "illegal" is to be interpreted as illegal in the state of Texas :p
Some of you may ask why this is. It's simply because in texas, they apply the death penalty to more crimes than any other state. :D
