Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
hey guys, is there anyway to partition a ram, to say like, run a program or install a program onto it. Say like i wanna install a file, and then when i shut off the computer it wipes out.
Just curious, all information would help
Thanks much
peece -
Its called a RAM Disk
there are both software versions that employ system memory
(a startup disk employs a RAM drive)
and hardware RAM Drives, based on SDRAM, and various Flash Techologies (often called SSD, Solid State Disks)
