firas
- Oct 29, 2006
Hi all,
Ive partitioned my primary hard drive (640GB) to three equal partitions (about 200GB each)
C for Vista
D for XP, which I dont use at all so this partition is practically empty
E for data
what I know is that the first or primary partition will be located on the fastest outer edge segments of the hard drive by default when you set up multiple partitions
and the more space (percentage) you use from the primary partition the slower the OS will get
so all games are installed on C and now Im using about 180GB from it
and Im thinking of taking 100GB from D and add it to C
and ideas?
C for Vista
E for data
and ideas?
