scottatwittenberg
- Apr 10, 2002
so i installed windows on this used laptop today.. all was working well.. and then it got knocked onto the floor.. after that it ran like crap..
so i went to reformat the hard drive thinking it would find the bad sectors... and just mark them bad and format around them..
well.. twice in a row, it got to 46% and started clicking, like the arm is going all the way to the edge of the drive..
so, being a 20gb drive.. i made an 8gb partition, put windows on it.. and it works great..
now i am trynig to format the rest of teh drive in disk managment.. its doing the same thing once it hits 6%.. which is wha ti thought it would do..
so how can i just skip the next 10% of the drive.. and then format another 8 or so gb on the end?
do i need 3rd party software like partition magic? or can i do it in comp mgt somehow..
oh, and just curious.. what kind of damaged happened to the drive? i would that constitute a head crash? spinning drive gets dropped.. and heads rub across a section of the drive.. somethign like that?
