I am putting together an i7 build, and just got a 300gb velociraptor for the main disk. Motherboard is the gigabyte ud3r. I'll be installing vista64 (home premium), and my use of the system is mainly gaming (WoW, TF2, and newer games), and daily web/email use. Fast performance in OS and fast performance in games (loads etc) are both desired equally. I won't be going SSD at this time.
Should I partition the velociraptor into a 50gb os partition and 250gb games/apps partition?
Last system I built (with a 10k raptor several years ago), this is what I did, as it was recommended at the time. I've since read that partitioning a fast drive like the velociraptor can hurt performance...on the other hand I can make the cluster sizes on the larger games/apps partition a bit larger (was thinking 32K) which I know boosts read speeds.
Where should the page file(s) go? On my current system there is pagefile on both the large partition of the boot drive (10k raptor), and another on a 200gb 7200rpm WD drive.
Other drives in the new system will be an existing 80gb raid1 made of 2 80gb 7200.7 seagates (on the gigabyte controller, no need for speed, this data is rarely accessed) for my vital data (also backed up off site), and the 200gb 7200rpm WD above, which will share the ICH10R with the velociraptor and a SATA cd/dvdrw. The old 10k raptor will stay in the other system. The velociraptor will be the only fast drive.
