Partition terminology
silk186
I'm looking at my partitions in disk manager and I'm a bit confused
primary/logical, active/none and MRB
I tried looking it up online but I found very long articles that didn't explain it very well.
Again, thanks to daglesj for recommending Active@Partition Recovery
here's a little info that may explain it:
http://windows.microsoft.com/en-us/windows-vista/what-are-partitions-and-logical-drives
http://www.symantec.com/security_response/glossary/define.jsp?letter=p&word=primary-partition
regarding MBR:
MBR is the standard partitioning scheme that's been used on hard disks
It supports 4 primary partitions per hard drive, and a maximum partition size of 2TB.
GPT is a newer technology, a The GPT disk itself can support a volume up to 2^64 blocks in length. (For 512-byte blocks, this is 9.44 ZB - zettabytes. 1 ZB is 1 billion terabytes).
