Hi guys,
I just installed Win7 Home Premium, up from Vista Home Premium, and I've noticed that my programs and the OS in general are less responsive than they used to be. I find this odd because alot of the things I've read touted 7 as much snappier.
The other major change I made while shuffling stuff around was that formerly (while running vista) I had partitioned off about 150 gigs on my 640 WD Caviar black to serve as the OS/App drive, and then I utilized the rest of the drive and my 320g seagate for storage.
This time around I simply installed Win7 on the 640 without partitioning it, so OS and Apps would have more space ( I was running out before, Vista was taking up a ton of space.)
So with the noticeable slowdown, I want to redo this setup again before I spend too much time tweaking the OS and installing all my apps again.
Can someone with some experience here please tell me the best route to take? I want my OS and primary applications (Games, Visual Studio 2008, Photoshop) to be as fast as possible given my setup, I'll need at least 200 gigs of space for this (I like to keep alot of games installed at once).
As I see, the options are:
A.
640 -
Partition 1 ~200 gigs - OS, Apps
Partition 2 ~400 gigs - storage
320 -
Storage
B.
320 -
Partition 2 ~100 gigs - storage
640 -
Storage
C.
320 -
Partition 1 ~320 gigs, OS, Apps
640 -
Storage
EDIT - Or is there any value in putting the OS one one drive, the apps on the other, and using 4 partitions: HD1: 1 OS, 2 Storage, HD2: 3Apps, 4 Storage
I'm open to any other suggestions, I'm just annoyed that it got slower with the 7 install.
Thanks much in advance for any suggestions and feedback.
Limey
A.
640 -
320 -
Storage
B.
320 -
640 -
Storage
C.
320 -
640 -
Storage
Limey
