The Difference Between Tracks and Cylinders
A hard disk is usually made up of multiple platters, each of which use two heads to record and read data, one for the top of the platter and one for the bottom (this isn't always the case, but usually is; see here for more details). The heads that access the platters are locked together on an assembly of head arms. This means that all the heads move in and out together, so each head is always physically located at the same track number. It is not possible to have one head at track 0 and another at track 1,000.
Because of this arrangement, often the track location of the heads is not referred to as a track number but rather as a cylinder number. A cylinder is basically the set of all tracks that all the heads are currently located at. So if a disk had four platters, it would (normally) have eight heads, and cylinder number 720 (for example) would be made up of the set of eight tracks, one per platter surface, at track number 720. The name comes from the fact that if you mentally visualize these tracks, they form a skeletal cylinder because they are equal-sized circles stacked one on top of the other in space.
latief75 said:i always split harddrives to get one for backup and one for windows ... just incase i need to install it again .....
