Paranoid & OCZ 600 Watt
DrDoU
Have a OCZ 600 watt StealthXstream with the setup on sig.Have been reading reviews and I am now wondering if this unit will survive the overclock as I push it higher.Ripple is my main concern.Do I need to ditch this unit and replace with Antec?
How long have you had the unit?
I ran a 600SXS more heavy rig on mine which I got on October 08. Power supply powered my changing rig very well, E5200>E5400>E7200>E7400>E8400>Q6600>E5200>Q9550 paired with a EP45-UD3R, 8GB DDR2 @ 960, 9800GTX (65nm) @ 825/2026/1225 and a 9600GT for physx. The unit does have a higher fail rate after its first year use but with the time I used it for well over a year and 3-5 months it took a hell of a beating with constant 24/7 use.
I replaced it with the Shellshocker ETASIS ET750. Still never had a problem with it yet I asked the same a while back. I say continue using it if money is an issue, if not pick up a Antec Earthwatts 500+ model and call it a day.
That PSU tends to exhibit excessive ripple at loads around 500W and up. You aren't anywhere near that, so you don't have to worry. It's not a great PSU, but it shouldn't cause you any problems.
Been running about 6 months now and I have had no problems.It never gets hot and is whisper quite.System is not pushed 24/7 so that may be a plus for me.Still,I might get a Antec anyway.Thanks.
Thanks for the input.Since the unit is not being pushed I'll just hang on to it.
