Parallel to SATA and MM5 question
TITAN24
Ive got 2 questions today....
The first is ive got a raptor 74g with my os on it running off sata and ive also got a regular wd 40g that i want to hook up but when ever i try and hook it up it just tries to format and install an os on it and says i have no serial drives. Is there a cable to change from parallel to serial or away to hook up the 2 at the same time? Ive got a asus p4c800-e dlx and i havent found anything in the bios that allows this. Ive been told the cable to switch to sata is real but i havent been able to find it. Is it real or does a friend just not know what hes talking about?
My second question is i just got motherboard monitor 5 on my pc and it gives a different reading then my case monitor sensor. Im pretty sure that i installed the sensor that came with my case right on my proc but i get a very diff reading between the 2. I get 56 C with the one i installed myself that came with my case and 30 C with the program motherboard monitor 5. Which one should i really trust?
Thanks for any imput you can give me on either question.
as long as it has sata.:rolleyes:
but you should get an abit board since they are 5 times better than asus. imo;) :D
lol well since i just got my asus im going to stay with it but thanks i think i will try it anyway...
any idea on my other question?
