I have an industrial piece of equipment that leads to a control box. From that control box, there is a serial cable that leads to the computer, which has the software on it for viewing data, printing reports, etc...
There is a 2nd cable that comes out of this control box that has 7 wires in it, but it goes to a parallel port plug. This plugs into a printer, which is a special printer that takes paper like a credit card terminal.
We want to print to file instead of this antiquated printer. The vendor doesn't support this and is zero help. My thoughts are to purchase a parallel card for a computer, and try to install some type of software that acts like a parallel printer... has anyone ever does anything like this before? I'm not sure if that will even work, or if there is a different solution I should look at.
Any help/ideas/guidance would be appreciated, thanks!
