Parallel or Serial Bridge?
Creepin_D
Looking to water cool my 7970's, and I was wondering which is the best way to go? Parallel or Serial? I plan on getting some sort of EK block, along with a 120x2 rad and MCP655 pump. Which one will get me better cooling? Thanks
I recommend against using EK blocks. Since you have a 655 pump, you would benefit better from a parallel setup.
Reason's why you are against? Availability is one of the reason why I may be getting an EK block.
Nickel plating quality issues and poor customer service.
Second on the parallel connection.
Parallel connection has less restriction.
But also less flow-rate through each block. Thus, if you have a high presssure pump that can handle the restriction series works better, and if you have a low pressure pump with high flow rate parallel works better.
Word up. Thus 655 = parallel. :)
Are we sure series yields lower temps though?
Hey guys, thanks for all of your reply's......today i picked up a 780, so I will not be keeping my 7970's. I will keep this thread open in the mean time....great info for anyone else looking :cool:
