Papst 60mm Fan
md262626
I just wanted to share. If you're looking for a kick ass 60 mm fan with nearly the output of a Delta Black label but not nearly as much noise look no further than a Papst 612NHH. I just picked one up and here's the specs:
60 mm
6,850 rpm
33 cu. ft/min
32 db
12V
3.0 Watts
3 pin molex/2 wire (no tach)
The thing is a monster for a 60mm and while a little loud, not bad once it's in your case.
what are you using it for? kinda small for anything but a stock/old heatsink isnt it?
