Pantone Huey Pro - $50
Zoomer
Newegg has this calibrator for $50 with promo code EMCKDGK33
The last calibrator on here was $100, though that is supposedly better.
i so confused. who would use these? i'm being serious
Individuals who are concerned with color reproduction and accuracy beyond what the naked eye can properly calibrate. Also, those who have multiple-displays and are very specific about uniform brightness, contrast, luminosity, and color across all displays.
Another good thing is that these have decent resale value.
Hold onto the box, literature and all of the accessories and you could easily recoup 75% of your purchase price on Ebay, and at this sale price you can probably recoup more than that.
Using the Xrite Eye One LT calibrator on my projector and monitor was the best $100 I ever spent. It makes an INCREDIBLE difference in overall contrast, vividness, etc, etc. It felt like I bought a $4000 projector instead of my entry level $500 one.
I'm not sure how good this one is compared to the X-Rite, which is said to be better, but if it's even half of the Xrite you won't be dissapointed.
I don't know much about calibrators. I do mingle with amateur photography though, and have already wrestled a little with color issues on my wide-gamut 2709 dell.
Would this work for a wide-gamut display?
Thanks for sharing. The $100 deal on amazon appears to be still up. Did you manage to figure out if the Xrite you got was fresh?
Would this be good/ compatible with an eyefinity set up (3x20wmgx2's)?
From my experience with similar devices, yes. You use the calibrator per screen, it'll make a per-screen profile.
I can't exactly remember if you have to leave the calibrator connected or not (people could buy them, use them, then return them if not).
The deal up above seems dead. But I did find this one:
http://www.provantage.com/pantone-eodis2~APANT09H.htm
X-Rite EyeOne Display 2 (one up from the $99 on Amazon) for $99 and comes with a $25 mail in rebate for $74 plus $5 shipping (for me).
They appear to drop-ship (hence the "extra 2 days"). But I took the gamble anyways. That's 50% off what Amazon wants and these regularly (I checked Ebay just now) sell for $130+shipping on Ebay as of today.
Im reading that calibration does not work in eyefinity mode since windows will see the monitors as one big monitor rather, so it would only apply one profile, rather than 3 separate profiles for each screen...
Unless i'm uninformed of a fix for that...
No idea if this would work, but you could try to disable eyefinity, calibrate, then re-enable eyefinity.
I can see what he's saying.
I wouldn't know though, I don't use eyefinity as I can't stand having my taskbar on the far left and having my windows spanned like they do in it. It's great for games though and having to switch in/out is a PITA (even with shortcuts, that are buggy).
Granted, I haven't tried it in about 3 months or so, so it could be much better.
