panda question.
rxteenager
My question is, how good is this thing? I just got a free copy from a friend. What would be a lighter option? Im only running an athlon 1.5ghz with 352 ram. So i need some protection, and im very broke and since this thing was free, what would be a free alternative?
Wilders Security Forums are a big hangout for antivirus and firewall experts. Those who live and breath these products.
Panda is one of the most joked about AV products for being bloated and slowing your system to a crawl over on their forums. Yes...even more than Symantec and McGufee.
You have free alternatives which are FAR superior.
IMO the best free AV product..that is better than most paid for AV products....
AVS...made/powered by Kaspersky, offered free through AOL. You don't NOT have to sign up with AOL, you do NOT need to install any other AOL software.
http://www.activevirusshield.com/antivirus/freeav/index.adp?
Just remove the checkbox to install the toolbar.
Second free one....Antivir
http://www.free-av.com/
I'm not fond of AVG anymore...poor detection rates based on personally working on many computers...seeing it fail to detect and remove bad guys that other AV products easily find, and I've cleaned many PCs that were infected even though they were using AVG.
Avast...while it has good detection, it slows down your PC too much.
well thanks, i have been hearing about Kaspersky, i guess i will have to check it out.
totally agreed on panda. my boss got it a few years ago and I hated it - bloated, horrible management / installation, fucked updates ("the panda pause").
switched to NOD32 and i'm in heaven (namely, I don't ever have to think about it).
Well I have seen great comments about NOD32, the only thing is. Im totally broke... so i guess that's out of the question then.
While some of the Panda products do weigh down the system, they are mostly the high-end retail products. The corporate AdminSecure is one of the best products I've ever seen. The best bet if you want to go with Panda is to get the lowest end retail product, just the anti-virus protection and you won't get any problems.
