Panasonic TH-50PHD8UK Plasma TV
Axsuul
It's a pretty new plasma TV but I haven't been able to find any reviews for it, anyone know of any or own this? THanks for your time.
It's a very good display. It corrects many of the minor problems with the 7th gens. Keep in mind that this is a commercial display. It does not have any of your common inputs. It requires a special "blade" for things like DVI and HDMI. These will run you a couple hundred extra. Also keep in mind that they don't include an HD tuner. May I ask why you are considering a commercial display over their excellent consumer models?
Because I wanted to get the Panasonic TH-50PHD7UY (that's a consumer model right) but alot of online retailers said it was discontinued and that this model is replacing it.
btw I can always get a SDI/HD-SDI terminal for this display if I need high-definition (not like theres a whole load of hd channels in the first place)? The TV itself seems pretty cheap ($3200 online w/ shipping).
The Tv is cheaper than the consumer models because it doesn't come with any tuners, speakers, stands, or common inputs. The other model you mentioned is being replaced, but it was a commercial model as well. They only come with BNC connectors, unless you buy an optional blade. They do have more calibration options, but they are certainly lacking in other features.
Your best bet is to look at something like the 50px50U. If you need a PC input then look at the 500U. These are the consumer versions. They are excellent performers and have plenty of features. You can find some very good prices for these at www.bestbuyplasma.com. You can find good deals on the commercial variants at www.visualapex.com.
There's plent of HD content out there. Almost all of the big prime time shows are simulcast in HD. Besides, DVD's look great on an HD screen...make use of a HDMI input here and use a good upscanning DVD player with HDMI out.
Hey logo, thanks for the suggestion, it looks like a nice TV (btw, the 50PX50U has an expansion slot for PC support right?) but I'm just wondering can you take off those speakers that come with the TV or are they built in?
The consumer models do not have expansion slots. However, the 500u does come with a VGA port. The 50u does not. I believe that the speakers on the 500u are removeable but I'm not sure. IRC, the 500u has two speakers, one on each side while the 50u has the speakers at the bottom.
The 50u has 2 speakers (bottom) and the 500u has 6 (bottom and sides). The 500u speakers are not removeable....they are part of the bezel. I own the 50u, BTW.
The commercial models have been reviewed very favorably and have a neutral color decoder while the consumer model has some red and green push.....very typical of consumer plasmas. I would not hesitate at all to get the commercial model. Go to the AVS forum and specifically here for lotsa discussion of these TVs.
http://www.avsforum.com/avs-vb/showthread.php?t=576903&page=1&pp=30
You are right. The 500U's speakers are not removeable. I was mistaken.
I have to disagree with you on using the commercial model for your average invidividual. Even over HDMI, the commiercial model with a STB won't begin to compare with a consumer model using a CC in terms of PQ. The commercial model just requires to many extras for your average individual. It's great if you already have a nice sound system and will be watching mostly DVD's. I haven't heard any issues with color pushing on these displays. I'd imagine that they'd both have almost identical PQ if the commercial model wasn't professionally calibrated. In the past the commercial models have had problems with black level stability. I haven't heard any reports as to whether this has been resolved with the 8th gens.
