Panasonic TC-37LZ85 PC Resolution Problem Help
OliverBGD
Hi,
I recently bought a Panasonic TC-37LZ85 after reading great review from people using it as a PC monitor. My problem is that when I put the display on 1920x1080 bottom of Vista Start Menu is missing and text is too small to read by sitting 2 meters away from it. How can I fix it. The only resolution so far that is making the text readable at a distance seems to be 1184x666.
P.S. I got prefect sight, I don't wear glasses.
There is a size setting in the video menu on the monitor. One setting has overscan and will crop, the other gives you 1:1. Fix that first.
As far as using another resolution. I would suggest scaling the text in windows first or sittng closer rather than using lower resolutions.
i have the 37lz800 and sitting about 5-6 feet away, 1920 by 1080. i started with 96dpi and my eyes get tired if i read text for 3+ hours so i change it to 120dpi and it helps alot. the text is still sharp
Thank you guys for tips, I changed HD size to 2 instead of 1 and it'd didn't crop anymore at 1920x1080. It looks amazing when I sit close but if I sit about 8 feet away it strains my eyes when I read text. What can I do in windows to help besides putting text at 120DPI?
