Panaflo Fans
I have a 92mm H1A. As some of you may know, it doesn't come with a molex connector. I know you can buy 3-pin molex connectors, but are there any places I can buy connectors with RPM sensing?
I've heard you can only buy it directly from Panasonic...
But i'm not sure.
Just construct a fanbus and rheobus (or 7v/12v switch) to run the fans at high and low RPMs.
you can get them cuz i bought a couple of fans from akasa that have got it, i dont know where you can buy them though, search about.
The Molex connector with RPM is useless unless it's an RPM sensing fan.
You can get the three pin connector at FrozenCPU.com
They also sell the RPM sensing fans, just so your're sure it's actually got the RPM sensor.
The vast majority of panaflos do not have RPM sensing. Only the recent revisions of the most popular fans do.
Yea, I have 8 panaflo fans here and not one of them has RPM sensing.
