Just wondering if anyone knows somewhere to buy them?
Specifically i want models with higher cfm than the default Lian-Li PC60 80mm flans to increase the air flow in my new SLI rig. I have no idea what the manufacturer of the default fans are in the PC60 so I can't figure out how much more CFM rated ones I'd need, but i can't find anywhere that does the range of panaflo fans in the UK.
I think I'll remove the internal fan covers too since they seem a bit hindering to the air flow. Are they easy to remove? Looks like black rubber pins holing them to the fan... Also, can anyone confirm which direction the top fan should be blowing? In or out? Since a few people have said different things.
Even ebay.co.uk seems a bit sparse all I can find is the low cfm models (21cfm 19dba) whcih wont be enough I wouldn't have thought.
Please help with some info. or some alternatives. If not panaflo then what for the same performance?
Thanks
Thanks
