What do you guys usually use to paint the plastic part of the front of a case?
I picked up some Krylon paint today to do the rest of it, but will that work on plastic as well? what grit do you usually use to sand the plastic? my case's front has lots of pits that i can't get into, so i'm hoping that the paint will stick in there. it's a chaintech full-tower that i bought a few years ago.
thanks.
thanks.
