Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a Centurion 5 case and I want to paint the inside of it but it seems like I can't take out the racks because they're attached to the case with these:
What do you suggest I do? Can I even get these off?
you can drill those out, just take a drill that is a bit thicker than the other inside of the rivet.
Just drill till you hit the case gently, than the iron comes of and than you can take the rivet out
