Manaknight
- Jun 6, 2005
hey all
i'm finishing my current mod for a client, its nothing special just a repaint and a few new windows and lights, however i had to take an ugly beige case and make it black, i did all the metal parts with some krylon, wet sanding and clear coat. however now i'm at the front panel which is plastic. im not sure what to use however, should i use the krylon fusion paint? or is my standard stuff cool? and do i need to prime it same as the side panels? painting the front panel is a first for me. any help would be great
